O que você precisa
Remove five Screens T20 from the bottom and lift the bottom plate up.
Separate nine cables.
Remove all screws from the electronic box.
Remove the electronic box.
Tilt the machine head.
Remove the security washer from the hinge axle.
Remove the axle and the machine stand.
Pull the spring out.
Remove the screw.
Remove the design plate.
Remove two screws T20.
Remove the top cover. Note: the cable connecting the top cover and the lower case is very short.
Remove the screws from the "Light on/off"-unit and separate it from the top cover.
Using a punch and a hammer push out the pin. (Note: support the gear on the opposite side to protect the the motor shaft from damage).
The gear ist free.
To reassemble your device, follow these steps in reverse order.
5 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
VauWeh está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
13 comentários
super Anleitung
hat problemlos geklappt
vielen Dank.
PS: ist schon ein bisschen aufwendig, nur um den Antriebszahn zu wechseln, die gesamte Maschine zu zerlegen.
Gruß Rainer
Great tutorial, however it does not apply for me, as I have a Kenwood titanium KMY60 model, this spare part does NOT have a pin. I can’t say how it is fixed to the gear, could you advice on how to disassemble it?
Hi, how did you manage to disassemble the part without the pin? How is it fixed? Thank you!
Danke für die Anleitung. Wir haben angefangen, nach Gutdünken loszuschrauben und sind kläglich gescheitert. Mit der Anleitung hat es geklappt. Vielen Dank dafür!
Ich bin selber Ingenieur und konstruiere mechanische Bauteile und bin doch sehr verwundert, das Kenwood dermaßen kompliziert baut.
