Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The speakers on a Kensington Hi-Fi Headphones 33137 provide sound to the user and are a crucial component in the headphones. This guide shows how to remove this component.
O que você precisa
Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
With the internal speaker component exposed, the wires connecting the speakers to the speaker cable can be cut.
Cut each of the wires connecting the speaker to the speaker cable.
Repeat this process for each speaker.
To reassemble your device, follow the instructions in the Kensington Hi-Fi Headphones 33137 Speaker Cable Replacement.
Uma outra pessoa concluiu este guia.
