Introdução
The speaker cable on the Kensington Hi-Fi Headphones 33137 connect the headphones to an audio device. This guide shows how to remove this component.
O que você precisa
Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
With the internal speaker component exposed, the wires connecting the speakers to the speaker cable can be cut.
Cut each of the wires connecting the speaker to the speaker cable.
Repeat this process for each speaker.
After cutting the wires, untie the knot that is in the speaker cable.
Repeat this process for each side of the speaker cable.
To reassemble your device, follow the instructions in the Kensington Hi-Fi Headphones 33137 Speaker Cable Replacement.
