Introdução
Here we have a Kenmore 90 Series that will not start its spin cycle. This occurs when the motor coupler connected to the drive motor has been worn over time. In this guide, you will will learn the step-by-step process of replacing this component. Prior to beginning your repair, be sure to unplug the washing machine.
O que você precisa
Using a flat head screwdriver, gently wedge the end caps off of the control console in order to open it up.
