Ir para o conteúdo principal
Kenmore 78423 Dustbin fiber collector Replacement
  1. Kenmore 78423 Dustbin fiber collector Replacement, Dust Bin: passo 1, imagem 1 %32 Kenmore 78423 Dustbin fiber collector Replacement, Dust Bin: passo 1, imagem 2 %32
    • Grab the dustbin handle, press and hold the button at the top of the handle.
    • Pull the dustbin up and away from the main body.
  2. Kenmore 78423 Dustbin fiber collector Replacement: passo 2, imagem 1 %32 Kenmore 78423 Dustbin fiber collector Replacement: passo 2, imagem 2 %32
    • Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin.
    • Properly dispose any contents of the dust bin into a wastebasket.
  3. Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: passo 3, imagem 1 %32 Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: passo 3, imagem 2 %32 Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: passo 3, imagem 3 %32
    • Grab the fiber collector using the finger holes on both sides of the base.
    • The fiber collector is the black basket with the rounded base
    • Turn the base a quarter-turn clockwise and pull it away from the dustbin
    • Remove the fiber and hair that may be stuck inside the fiber collector
Conclusão
Equipe
CSU Fullerton, Team S2-G4, Bruce Fall 2018 Membro de CSU Fullerton, Team S2-G4, Bruce Fall 2018
CSUF-BRUCE-F18S2G4
Membros da 4
Autoria de 10 guias
Um comentário
thank you for your help. My sister in law didn’t have the manual, its typical of her husband. without the manual I probably would have broken the fiber collector. Appreciate your help.
joseph doyle - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 488
