Ir para o conteúdo principal
Kenmore 110 Series Washing Machine Water Pump Replacement
O que você precisa
  1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: passo 1, imagem 1 %32
    • Unplug the washing machine!
    • Carefully lay washing machine on its back.
  2. Kenmore 110 Series Washing Machine Water Pump Replacement: passo 2, imagem 1 %32 Kenmore 110 Series Washing Machine Water Pump Replacement: passo 2, imagem 2 %32 Kenmore 110 Series Washing Machine Water Pump Replacement: passo 2, imagem 3 %32
    • Carefully remove both wire harnesses connected to the pump.
    • Squeeze and pull back hose clamp.
    • Twist drain hose off of pump.
    • Using a 1/4" socket wrench, remove the three mounting screws.
    • Pull the pump out of place.
    • Pulling the pump away takes a little force.
Conclusão
14 outras pessoas executaram este guia.
Robert Trout
Membro desde: 09/26/12
1.234 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 15-43, Forte Fall 2012 Membro de Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
Membros da 5
Autoria de 11 guias
9 comentários
please provide info on how to test the water pump once it's removed...
Oscar Ramos - Responder
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - Responder
My clothes are still really wet.
Tracy Schultz - Responder
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - Responder
I had to use a pump and pump it out of the drum to effect repairs to the pump
Ryan Curtis -
Lint on clothes when come out of washer
Mike Schladweiler - Responder
Drain Pump runs—No water comes out.
Solution:While pump is running I take a rubber hose narrow enough to fit into part of the kitchen tap connector where the water drains from (You all know this but they're making someone who's never actually noticed...there are two chambers in the tap connector. One is to get water from the button while the machine is running. The other is for the drain water).
I wrapped my hand around the rubber hose and hold it tight against the tap connector to make it airtight. I then blow air into the small hose until I can hear it bubble into the washer..Reminder do this while the pump is running. Get your face away from the hose the moment you hear the bubbles. The water comes suddenly and with full force
I bought my Kenmore portable new from Sears for $600 in the year 2000. It owes me nothing and has never had a problem This drain problem started a couple of years ago after I'd had a cat that shed like crazy for a year. He's gone and problem remains intermittently.
Walter-KEMBLE WellBredNfed - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 77
Últimos 30 dias: 344
Duração total: 58,783
