Ir para o conteúdo principal
Kenmore 110 Series Washing Machine Water Pump Replacement
O que você precisa
  1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: passo 1, imagem 1 %32
    • Unplug the washing machine!
    • Carefully lay washing machine on its back.
  2. Kenmore 110 Series Washing Machine Water Pump Replacement: passo 2, imagem 1 %32 Kenmore 110 Series Washing Machine Water Pump Replacement: passo 2, imagem 2 %32 Kenmore 110 Series Washing Machine Water Pump Replacement: passo 2, imagem 3 %32
    • Carefully remove both wire harnesses connected to the pump.
    • Squeeze and pull back hose clamp.
    • Twist drain hose off of pump.
    • Using a 1/4" socket wrench, remove the three mounting screws.
    • Pull the pump out of place.
    • Pulling the pump away takes a little force.
Conclusão
13 outras pessoas executaram este guia.
Robert Trout
Membro desde: 09/26/12
1.168 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team 15-43, Forte Fall 2012 Membro de Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Membros
10 Guias de autoria
7 comentários
please provide info on how to test the water pump once it's removed...
Oscar Ramos - Responder
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - Responder
My clothes are still really wet.
Tracy Schultz - Responder
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 104
Últimos 30 dias: 457
Duração total: 54,298
