Ir para o conteúdo principal
Kenmore 110 Series Washing Machine Water Level Sensor Replacement
O que você precisa
  1. Kenmore 110 Series Washing Machine Water Level Sensor Replacement, Water Level Sensor: passo 1, imagem 1 %32
    • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury. Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: passo 2, imagem 1 %32 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: passo 2, imagem 2 %32 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: passo 2, imagem 3 %32
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: passo 3, imagem 1 %32 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: passo 3, imagem 2 %32 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: passo 3, imagem 3 %32
    • Remove wires from water level sensor.
    • With a Phillips screwdriver remove the mounting screw.
    • Cut the zip tie and remove water level hose.
Conclusão
5 outras pessoas executaram este guia.
Robert Trout
Membro desde: 09/26/12
1.234 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 15-43, Forte Fall 2012 Membro de Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Membros
Autoria de 12 guias
4Comentários do guia
how to test water level switch??
countryrhoads4x4 - Responder
What is the water sensor part # for a Kenmore model #11029842990?
Who has that part 4the best price?
Rod Brannon - Responder
Hi,
I replaced the water-level pressure switch with a new kit but it did not resolve my problem. After installing the switch and line, I selected the lowest level but the tub continued to fill beyond the smallest wash level. I have a Kenmore Model # 110.20902. What other part or solution could resolve my issue?
BTW: I read replacing the water inlet valve night be involved but I already did that within the last six months and everything worked fine until I noticed the water level had changed the last two washes to a large load only. In fact, the water looked above the large level during my last wash.
I would appreciate any insight.
Shannon
Shannon - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 67
Ao todo: 42,616
