Ir para o conteúdo principal
Kenmore 110 Series Washing Machine Electronic Control Replacement
O que você precisa
  1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: passo 1, imagem 1 %32
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Electronic Control Replacement: passo 2, imagem 1 %32 Kenmore 110 Series Washing Machine Electronic Control Replacement: passo 2, imagem 2 %32 Kenmore 110 Series Washing Machine Electronic Control Replacement: passo 2, imagem 3 %32
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Electronic Control Replacement: passo 3, imagem 1 %32 Kenmore 110 Series Washing Machine Electronic Control Replacement: passo 3, imagem 2 %32
    • Carefully remove the three wire harnesses.
    • With a phillips head screwdriver, remove the three mounting screws.
Conclusão
10 outras pessoas executaram este guia.
Robert Trout
Membro desde: 09/26/12
1.234 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 15-43, Forte Fall 2012 Membro de Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
Membros da 5
Autoria de 11 guias
3 comentários
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - Responder
I am having the same problem. Did you ever find a fix?
Paul Bennett -
Did anyone find a fix for this problem?
Ron Rafe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 37
Últimos 30 dias: 154
Duração total: 27,618
