Ir para o conteúdo principal
Kazoo Diaphragm Replacement
O que você precisa
  1. Kazoo Diaphragm Replacement, Diaphragm: passo 1, imagem 1 %32
    • Lay your kazoo down on a flat surface.
  2. Kazoo Diaphragm Replacement: passo 2, imagem 1 %32 Kazoo Diaphragm Replacement: passo 2, imagem 2 %32
    • Untwist the cap in the middle of the kazoo and set it to the side.
  3. Kazoo Diaphragm Replacement: passo 3, imagem 1 %32 Kazoo Diaphragm Replacement: passo 3, imagem 2 %32
    • Take the damaged diaphragm out with your fingers.
    • If you can't get the damaged diaphragm out with your fingers, turn the kazoo over and let the diaphragm fall out.
  4. Kazoo Diaphragm Replacement: passo 4, imagem 1 %32 Kazoo Diaphragm Replacement: passo 4, imagem 2 %32
    • Take a new diaphragm and place it back into the kazoo.
    • Twist the cap back on.
    • If you don't have any kazoo diaphragms, use scissors to cut a plastic wrapper or baking paper to the size of the hole and use that instead.
  5. Kazoo Diaphragm Replacement: passo 5, imagem 1 %32
    • Take some paper towel and spray isopropyl alcohol on it to wipe off any dirt or dust.
  6. Kazoo Diaphragm Replacement: passo 6, imagem 1 %32
    • Finally, let the kazoo dry off for 5 minutes, and it will sound new again. Happy playing!
Conclusão
Jose Meza
Membro desde: 10/26/22
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 27
Últimos 30 dias: 95
Duração total: 4,527
