Ir para o conteúdo principal
Katadyne Hiker Water Filter Cleaning
O que você precisa
    1. Katadyne Hiker Water Filter Cleaning, Katadyne Hiker Water Filter Cleaning: passo 1, imagem 1 %32
      • Remove the "snap fit" guard by pulling directly away from the filter body.
      Pergunte ao FixBot
      Comentar
    2. Katadyne Hiker Water Filter Cleaning: passo 2, imagem 1 %32
      • Remove the pump handle by pulling it completely out of the shaft.
      Pergunte ao FixBot
      Comentar
    3. Katadyne Hiker Water Filter Cleaning: passo 3, imagem 1 %32 Katadyne Hiker Water Filter Cleaning: passo 3, imagem 2 %32 Katadyne Hiker Water Filter Cleaning: passo 3, imagem 3 %32
      • Use the pump handle to remove the filter cap.
      • Place the horizontal groove of the pump handle depicted in image 1 onto the filter fins.
      • Press the pump handle firmly against the fins and turn the filter counter clockwise.
      • Once unscrewed, remove the filter completely from the body.
      Pergunte ao FixBot
      Comentar
    4. Katadyne Hiker Water Filter Cleaning: passo 4, imagem 1 %32 Katadyne Hiker Water Filter Cleaning: passo 4, imagem 2 %32 Katadyne Hiker Water Filter Cleaning: passo 4, imagem 3 %32
      • Only perform this step if solid particles are evident on the outside of the filter.
      • Lightly brush the entire filter with a soft bristled toothbrush under running water.
      Pergunte ao FixBot
      Comentar
    5. Katadyne Hiker Water Filter Cleaning: passo 5, imagem 1 %32
      • Replace the filter inside the filter body and screw clockwise until tight.
      Pergunte ao FixBot
      Comentar
    6. Katadyne Hiker Water Filter Cleaning: passo 6, imagem 1 %32
      • Lubricate the pump handle O-ring extensively with the Katadyne lubricant (sold with pump).
      Pergunte ao FixBot
      Comentar
    7. Katadyne Hiker Water Filter Cleaning: passo 7, imagem 1 %32
      • Replace the pump handle inside the pump handle shaft.
      Pergunte ao FixBot
      Comentar
    8. Katadyne Hiker Water Filter Cleaning: passo 8, imagem 1 %32 Katadyne Hiker Water Filter Cleaning: passo 8, imagem 2 %32
      • Replace the "snap-fit" guard by pushing directly toward the filter body.
      Pergunte ao FixBot
      Comentar
Conclusão
If difficulty pumping persists, a new filter is required.
Uma outra pessoa concluiu este guia.
Dylan Carey
Membro desde: 02/24/15
130 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 24-6, Green Winter 2015 Membro de Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Membros
Autoria de 60 guias
1Comentário do guia
wow. this is very helpful post.
thanks for nice guide line..
plz cheak out this—https://waterfilterhub.com
Kenny J. Jackson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 35
Últimos 30 dias: 102
Ao todo: 1,836
