Ir para o conteúdo principal
Katadyne Hiker Water Filter Cleaning
O que você precisa
  1. Katadyne Hiker Water Filter Cleaning, Katadyne Hiker Water Filter Cleaning: passo 1, imagem 1 %32
    • Remove the "snap fit" guard by pulling directly away from the filter body.
  2. Katadyne Hiker Water Filter Cleaning: passo 2, imagem 1 %32
    • Remove the pump handle by pulling it completely out of the shaft.
  3. Katadyne Hiker Water Filter Cleaning: passo 3, imagem 1 %32 Katadyne Hiker Water Filter Cleaning: passo 3, imagem 2 %32 Katadyne Hiker Water Filter Cleaning: passo 3, imagem 3 %32
    • Use the pump handle to remove the filter cap.
    • Place the horizontal groove of the pump handle depicted in image 1 onto the filter fins.
    • Press the pump handle firmly against the fins and turn the filter counter clockwise.
    • Once unscrewed, remove the filter completely from the body.
  4. Katadyne Hiker Water Filter Cleaning: passo 4, imagem 1 %32 Katadyne Hiker Water Filter Cleaning: passo 4, imagem 2 %32 Katadyne Hiker Water Filter Cleaning: passo 4, imagem 3 %32
    • Only perform this step if solid particles are evident on the outside of the filter.
    • Lightly brush the entire filter with a soft bristled toothbrush under running water.
  5. Katadyne Hiker Water Filter Cleaning: passo 5, imagem 1 %32
    • Replace the filter inside the filter body and screw clockwise until tight.
  6. Katadyne Hiker Water Filter Cleaning: passo 6, imagem 1 %32
    • Lubricate the pump handle O-ring extensively with the Katadyne lubricant (sold with pump).
  7. Katadyne Hiker Water Filter Cleaning: passo 7, imagem 1 %32
    • Replace the pump handle inside the pump handle shaft.
  8. Katadyne Hiker Water Filter Cleaning: passo 8, imagem 1 %32 Katadyne Hiker Water Filter Cleaning: passo 8, imagem 2 %32
    • Replace the "snap-fit" guard by pushing directly toward the filter body.
Conclusão
If difficulty pumping persists, a new filter is required.
Uma outra pessoa concluiu este guia.
Dylan Carey
Membro desde: 02/24/15
130 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 24-6, Green Winter 2015 Membro de Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
Membros da 4
Autoria de 15 guias
Um comentário
wow. this is very helpful post.
thanks for nice guide line..
plz cheak out this—https://waterfilterhub.com
Kenny J. Jackson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 28
Duração total: 770
