Introdução
Use this guide to remove and replace the vacuum motor in a Karcher Carpet Cleaner BRC3015C 2018.
O que você precisa
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Use a 3 mm hex key to remove two bolts securing the bottom cover.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
Use a 3 mm hex key to remove the four bolts securing the pump cover.
Use a flathead screwdriver to loosen the hose clamp securing the flexible hose to the vacuum motor.
Use a Phillips #2 screwdriver to remove the two screws securing the fan cover.
Use a Phillips #2 screwdriver to remove the screw securing the ground wire to the vacuum motor.
