Introdução
Use this guide to remove the pump cover in a Karcher Carpet Cleaner BRC3015C 2018.
O que você precisa
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Use a 3 mm hex key to remove two bolts securing the bottom cover.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
Use a 3 mm hex key to remove the four bolts securing the pump cover.
Uma outra pessoa concluiu este guia.
