Introdução
Use this guide to remove and replace one of the four switches on the Karcher Carpet Cleaner 10066730.
Follow this same procedure to remove the three other front panel switches. Note that the heater switch has an included light, so be sure to remove its accompanying power and ground wires if replacing.
The water switch and both pressure switches are part number 8.600-714.0, which the heater switch is part number 8.631-785.0.
Note: Before beginning repairs, disconnect the device from power, disconnect all hoses, drain and depressurize the system, and let the device cool if the heater was recently used.
O que você precisa
Use a Phillips screwdriver to remove the six screws securing the front panel.
Grip the front panel at the top and tilt down to reveal the switch electronics.
Grip the black ground wire by its blue connector and pull directly away from the switch to remove it.
Pinch the retaining clips on the back of the switch housing.
With all four retaining clips depressed, push the switch through and off of the front panel.
Remove the switch.
Uma outra pessoa concluiu este guia.
