Ir para o conteúdo principal
Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement
O que você precisa
  1. Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Removing Front Panel Screws: passo 1, imagem 1 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Removing Front Panel Screws: passo 1, imagem 2 %32
    • Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
    • Take care not to damage the buttons while maneuvering the front panel, with all six screws removed it may fall away.
  2. Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Lift the closure: passo 2, imagem 1 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Lift the closure: passo 2, imagem 2 %32
    • Hold the front panel steady while removing the plastic top/closure.
  3. Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Removing the front panel: passo 3, imagem 1 %32
    • Pull away the front panel carefully.
  4. Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Removing the rear panel: passo 4, imagem 1 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Removing the rear panel: passo 4, imagem 2 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Removing the rear panel: passo 4, imagem 3 %32
    • Remove the last 2.5mm Hex screw securing the rear panel.
    • Pull up on the rear panel to remove it from the roaster.
  5. Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Access granted: passo 5, imagem 1 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Access granted: passo 5, imagem 2 %32
    • Set the panels aside somewhere safe and bask in the beauty of your naked roaster.
  6. Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Disconnect the thermocouple: passo 6, imagem 1 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Disconnect the thermocouple: passo 6, imagem 2 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Disconnect the thermocouple: passo 6, imagem 3 %32
    • Use a 2.0mm slotted screwdriver to remove the thermocouple wires from the PCB-A
  7. Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Remove the tape: passo 7, imagem 1 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Remove the tape: passo 7, imagem 2 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Remove the tape: passo 7, imagem 3 %32
    • Carefully remove the foil tape from the roast chamber
  8. Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Removing the thermocouple: passo 8, imagem 1 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Removing the thermocouple: passo 8, imagem 2 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Removing the thermocouple: passo 8, imagem 3 %32
    • Unwind the thermocouple wire from the earth lead.
    • Pinch the thermocouple and gently remove it from the tube.
  9. Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Reassembly notes: passo 9, imagem 1 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Reassembly notes: passo 9, imagem 2 %32 Kaffelogic Nano 7/LINK (D-P Serial) Thermocouple Replacement, Reassembly notes: passo 9, imagem 3 %32
    • Leave 2mm of thermocouple insulation exposed
    • The thermocouple wires have connections points marked. Take care not to clamp the connector on the insulation.
    • Massage the tape firmly over the thermocouple wires to secure the position.
Conclusão
Kaffelogic
Membro desde: 07/23/25
2.098 Reputação
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 71
