Introdução
Replacement of an SSR on any Kaffelogic Nano or Nucleus Link coffee roaster with an A, B, C or N prefix serial number.
O que você precisa
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
Use a PH2 screwdriver to remove the two mains spade terminals.
Remove the 2x PH2 screws securing the SSR to the bottom of the gantry plate.
Conclusão
