Ir para o conteúdo principal
KYVOL CYBOVAC E20 Wheel Assembly Replacement
O que você precisa
  1. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Battery: passo 1, imagem 1 %32 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Start by laying the device on a flat surface with the logo facing up.
    • Flip the device over.
  2. KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 2, imagem 1 %32 KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 2, imagem 2 %32
    • Remove two 1 mm screws using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 3, imagem 1 %32 KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 3, imagem 2 %32
    • Remove the cover.
  4. KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 4, imagem 1 %32 KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 4, imagem 2 %32
    • Lift the battery.
    • Press down on the top of the white connector.
    • Remove the battery from the vacuum.
  5. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel: passo 5, imagem 1 %32
    • Remove both sweepers by pinching near the base of the brushes and pulling up.
  6. KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 6, imagem 1 %32
    • Remove four 10 mm screws using a Phillips #00 screwdriver.
  7. KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 7, imagem 1 %32 KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 7, imagem 2 %32 KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 7, imagem 3 %32
    • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
    • Disconnect the wheel motor from the power supply.
    • Repeat the process for the other wheel.
  8. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: passo 8, imagem 1 %32 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: passo 8, imagem 2 %32 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: passo 8, imagem 3 %32
    • Remove six 10 mm screws from the housing using a Phillips #00 screwdriver.
    • Open the gearbox.
  9. KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 9, imagem 1 %32
    • Gently remove each gear.
  10. KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 10, imagem 1 %32 KYVOL CYBOVAC E20 Wheel Assembly Replacement: passo 10, imagem 2 %32
    • Use a J1 screw driver to remove two 6 mm screws from the gearbox.
Conclusão
Randall Morgan
Membro desde: 07/13/23
380 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-1, Harley Summer 2023 Membro de IUPUI, Team 1-1, Harley Summer 2023
IUPUI-HARLEY-SU23S1G1
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 255
