Ir para o conteúdo principal
KYVOL CYBOVAC E20 Front Bumper Replacement
O que você precisa
  1. KYVOL CYBOVAC E20 Front Bumper Replacement, Front Bumper: passo 1, imagem 1 %32
    • Start with the vacuum on a flat surface.
    • The power button should be on the side closest to you.
  2. KYVOL CYBOVAC E20 Front Bumper Replacement: passo 2, imagem 1 %32 KYVOL CYBOVAC E20 Front Bumper Replacement: passo 2, imagem 2 %32
    • Flip the vacuum over so the bottom is facing up.
    • The dust bin should be on the side furthest from you.
    • Remove the eight 1 mm screws holding the bumper in place using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Front Bumper Replacement: passo 3, imagem 1 %32 KYVOL CYBOVAC E20 Front Bumper Replacement: passo 3, imagem 2 %32
    • Remove both sides of the bumper and replace with new ones.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 236
