Ir para o conteúdo principal
KPN Arizona Comfort Replacement
O que você precisa
  1. KPN Arizona Comfort Replacement, KPN Arizona Comfort: passo 1, imagem 1 %32 KPN Arizona Comfort Replacement, KPN Arizona Comfort: passo 1, imagem 2 %32 KPN Arizona Comfort Replacement, KPN Arizona Comfort: passo 1, imagem 3 %32
    • Hold the phone with one hand and apply a slight pressure on the battery lid with your other hand.
    • Now you can slide open the battery lid.
  2. KPN Arizona Comfort Replacement: passo 2, imagem 1 %32
    • Lift out both batteries with a prying movement.
  3. KPN Arizona Comfort Replacement: passo 3, imagem 1 %32 KPN Arizona Comfort Replacement: passo 3, imagem 2 %32 KPN Arizona Comfort Replacement: passo 3, imagem 3 %32
    • Remove the following two Phillips #00 screws securing the back casing to the front.
  4. KPN Arizona Comfort Replacement: passo 4, imagem 1 %32 KPN Arizona Comfort Replacement: passo 4, imagem 2 %32 KPN Arizona Comfort Replacement: passo 4, imagem 3 %32
    • Use the plastic opening tool to pry the front from the backside.
    • Start prying at the bottom and work your way around the device.
    • Do this for every 3 cm all around.
    • If you apply too much pressure or use a sharp tool, this might damage the casing.
  5. KPN Arizona Comfort Replacement: passo 5, imagem 1 %32 KPN Arizona Comfort Replacement: passo 5, imagem 2 %32 KPN Arizona Comfort Replacement: passo 5, imagem 3 %32
    • Flip the circuit board from the backside of the phone to the frontside of the phone by tilting it on the long edge
    • Make sure you do this gesture slowly and gently so the wires will not detach.
  6. KPN Arizona Comfort Replacement: passo 6, imagem 1 %32 KPN Arizona Comfort Replacement: passo 6, imagem 2 %32 KPN Arizona Comfort Replacement: passo 6, imagem 3 %32
    • You are now facing the back side. Apply a little bit of pressure with the plastic opening tool on the back of the speaker so the the speaker can pop out.
    • The speaker is still attached with a wire, do not pull this.
  7. KPN Arizona Comfort Replacement: passo 7, imagem 1 %32 KPN Arizona Comfort Replacement: passo 7, imagem 2 %32
    • Use a soldering iron to heat up the solder connected to the electric wire.
    • When the solder is fluid, carefully pull the electric wire loose.
  8. KPN Arizona Comfort Replacement: passo 8, imagem 1 %32 KPN Arizona Comfort Replacement: passo 8, imagem 2 %32
    • Replace the broken speaker of the phone and solder it back in place.
Conclusão
To reassemble your device, follow these instructions from step 6 in reverse order.
Uma outra pessoa concluiu este guia.
Maite
Membro desde: 03/08/17
131 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 450
