Ir para o conteúdo principal
KDDI Kyocera A5521K Speaker Replacement
O que você precisa
  1. KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: passo 1, imagem 1 %32 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: passo 1, imagem 2 %32 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: passo 1, imagem 3 %32
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. KDDI Kyocera A5521K Speaker Replacement: passo 2, imagem 1 %32 KDDI Kyocera A5521K Speaker Replacement: passo 2, imagem 2 %32 KDDI Kyocera A5521K Speaker Replacement: passo 2, imagem 3 %32
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: passo 3, imagem 1 %32 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: passo 3, imagem 2 %32 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: passo 3, imagem 3 %32
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. KDDI Kyocera A5521K Speaker Replacement: passo 4, imagem 1 %32
    • Remove the screws using a Y0 screwdriver.
  5. KDDI Kyocera A5521K Speaker Replacement: passo 5, imagem 1 %32 KDDI Kyocera A5521K Speaker Replacement: passo 5, imagem 2 %32 KDDI Kyocera A5521K Speaker Replacement: passo 5, imagem 3 %32
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  6. KDDI Kyocera A5521K Speaker Replacement: passo 6, imagem 1 %32
    • Use the Y0 screwdriver to remove the screws.
  7. KDDI Kyocera A5521K Speaker Replacement: passo 7, imagem 1 %32 KDDI Kyocera A5521K Speaker Replacement: passo 7, imagem 2 %32
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  8. KDDI Kyocera A5521K Speaker Replacement: passo 8, imagem 1 %32 KDDI Kyocera A5521K Speaker Replacement: passo 8, imagem 2 %32 KDDI Kyocera A5521K Speaker Replacement: passo 8, imagem 3 %32
    • Separate the faceplate from the phone.
  9. KDDI Kyocera A5521K Speaker Replacement, Speaker: passo 9, imagem 1 %32 KDDI Kyocera A5521K Speaker Replacement, Speaker: passo 9, imagem 2 %32
    • Turn the phone over.
    • Place a spudger in the oval shaped speaker opening of the phone (indicated by the red rectangle).
    • Turn the phone so the exposed circuit board faces upward.
    • Keep the spudger in the speaker while turning the phone.
    • The speaker is indicated by the yellow rectangle.
  10. KDDI Kyocera A5521K Speaker Replacement: passo 10, imagem 1 %32 KDDI Kyocera A5521K Speaker Replacement: passo 10, imagem 2 %32
    • Push the spudger through the speaker opening to separate the speaker (indicated by the yellow rectangle).
  11. KDDI Kyocera A5521K Speaker Replacement: passo 11, imagem 1 %32 KDDI Kyocera A5521K Speaker Replacement: passo 11, imagem 2 %32 KDDI Kyocera A5521K Speaker Replacement: passo 11, imagem 3 %32
    • Grasp the speaker (indicated by the yellow rectangle) with tweezers, or with your fingers if you can manage a firm grip.
    • Firmly remove the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Dominic Grisafe
Membro desde: 04/15/10
157 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 28-25, Regan Spring 2010 Membro de Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 13
Duração total: 1,842
