Ir para o conteúdo principal
KDDI Kyocera A5521K Front LCD Screen Replacement
O que você precisa
  1. KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: passo 1, imagem 1 %32 KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: passo 1, imagem 2 %32 KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: passo 1, imagem 3 %32
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  2. KDDI Kyocera A5521K Front LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the screws using a Y0 screwdriver.
  3. KDDI Kyocera A5521K Front LCD Screen Replacement: passo 3, imagem 1 %32 KDDI Kyocera A5521K Front LCD Screen Replacement: passo 3, imagem 2 %32 KDDI Kyocera A5521K Front LCD Screen Replacement: passo 3, imagem 3 %32
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  4. KDDI Kyocera A5521K Front LCD Screen Replacement: passo 4, imagem 1 %32
    • Use the Y0 screwdriver to remove the screws.
  5. KDDI Kyocera A5521K Front LCD Screen Replacement: passo 5, imagem 1 %32 KDDI Kyocera A5521K Front LCD Screen Replacement: passo 5, imagem 2 %32
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  6. KDDI Kyocera A5521K Front LCD Screen Replacement: passo 6, imagem 1 %32 KDDI Kyocera A5521K Front LCD Screen Replacement: passo 6, imagem 2 %32 KDDI Kyocera A5521K Front LCD Screen Replacement: passo 6, imagem 3 %32
    • Separate the faceplate from the phone.
  7. KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: passo 7, imagem 1 %32 KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: passo 7, imagem 2 %32 KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: passo 7, imagem 3 %32
    • Rotate the phone 180 degrees.
    • Grab the flexible circuit with tweezers (or use your fingers if you can manage a firm grip).
    • Pull the flexible circuit to towards you to separate the front LCD screen from the phone.
  8. KDDI Kyocera A5521K Front LCD Screen Replacement: passo 8, imagem 1 %32 KDDI Kyocera A5521K Front LCD Screen Replacement: passo 8, imagem 2 %32 KDDI Kyocera A5521K Front LCD Screen Replacement: passo 8, imagem 3 %32
    • Firmly pull the flexible circuit from the connector.
    • Be careful not to damage the flexible circuit.
    • The front LCD screen should now be separate from the phone.
Conclusão
Dominic Grisafe
Membro desde: 04/15/10
157 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 28-25, Regan Spring 2010 Membro de Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 1,502
