Ir para o conteúdo principal
KBD67 Lite R4 Keyboard Keys Replacement
O que você precisa
  1. KBD67 Lite R4 Keyboard Keys Replacement, Remove Keycaps: passo 1, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Remove Keycaps: passo 1, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Remove Keycaps: passo 1, imagem 3 %32
    • Place keyboard on top of a flat table.
    • Remove keycaps manually or with a key cap puller, as demonstrated.
    • Organize tools to prevent loss.
  2. KBD67 Lite R4 Keyboard Keys Replacement, Remove switches from PCB: passo 2, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Remove switches from PCB: passo 2, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Remove switches from PCB: passo 2, imagem 3 %32
    • These images showcase the correct utilization of a key switch puller.
    • Remove switches either manually or with a key switch puller.
    • A switch puller is recommended as hand removal might be difficult.
  3. KBD67 Lite R4 Keyboard Keys Replacement, Remove case (unscrew from back): passo 3, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Remove case (unscrew from back): passo 3, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Remove case (unscrew from back): passo 3, imagem 3 %32
    • Use screwdriver to unscrew the eight screws on back of keyboard.
    • Make sure to secure screws for later use.
  4. KBD67 Lite R4 Keyboard Keys Replacement, Remove PCB from case: passo 4, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Remove PCB from case: passo 4, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Remove PCB from case: passo 4, imagem 3 %32
    • Unscrew the PCB from case.
    • Avoid placing the PCB on static-prone surfaces to prevent it from shorting the switch sockets.
  5. KBD67 Lite R4 Keyboard Keys Replacement, Unscrew the stabilizers: passo 5, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Unscrew the stabilizers: passo 5, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Unscrew the stabilizers: passo 5, imagem 3 %32
    • Unscrew the stabilizers from the back of the PCB.
    • Keep track of the noise-reducing foam stickers screwed between the PCB and keyboard switches.
  6. KBD67 Lite R4 Keyboard Keys Replacement, Pull Stabilizers out of PCB: passo 6, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Pull Stabilizers out of PCB: passo 6, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Pull Stabilizers out of PCB: passo 6, imagem 3 %32
    • Use switch puller to take out stabilizers.
    • Once the stabilizers are unscrewed from the back, they can be removed from the PCB.
    • This completes the disassembly of the keyboard. Place the PCB in a static-free area.
  7. KBD67 Lite R4 Keyboard Keys Replacement, Place PCB on foam and plastic cover: passo 7, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Place PCB on foam and plastic cover: passo 7, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Place PCB on foam and plastic cover: passo 7, imagem 3 %32
    • Place the plastic and foam cover on the bottom of the keyboard case.
    • The PCB sits on top of the foam cover.
  8. KBD67 Lite R4 Keyboard Keys Replacement, Put stabilizers back onto PCB: passo 8, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Put stabilizers back onto PCB: passo 8, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Put stabilizers back onto PCB: passo 8, imagem 3 %32
    • Ensure noise-reducing foam stickers are in position before attaching the stabilizers.
    • Install stabilizers onto the PCB.
    • Screw where applicable.
  9. KBD67 Lite R4 Keyboard Keys Replacement, Replace switches into hot swap PCB: passo 9, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Replace switches into hot swap PCB: passo 9, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Replace switches into hot swap PCB: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    Microfiber Cleaning Cloths
    $3.99
    • Do not bend the switch pins.
    • Optional: You can clean the switches with a microfiber cloth.
    • Align the key switch pins with the corresponding holes on the PCB.
  10. KBD67 Lite R4 Keyboard Keys Replacement, Put PCB back into the case: passo 10, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Put PCB back into the case: passo 10, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Put PCB back into the case: passo 10, imagem 3 %32
    • Use the eight screws saved from the third step.
  11. KBD67 Lite R4 Keyboard Keys Replacement, Choose keycaps for Switches: passo 11, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Choose keycaps for Switches: passo 11, imagem 2 %32 KBD67 Lite R4 Keyboard Keys Replacement, Choose keycaps for Switches: passo 11, imagem 3 %32
    • Choose keycaps to place onto switches.
    • Optional: If you would like, clean the keycaps with a microfiber cloth or a bristled toothbrush before reattaching them.
  12. KBD67 Lite R4 Keyboard Keys Replacement, Test the switches and PCB: passo 12, imagem 1 %32 KBD67 Lite R4 Keyboard Keys Replacement, Test the switches and PCB: passo 12, imagem 2 %32
    • Plug the keyboard into a device of your choice and test its functions using appropriate software.
Conclusão
Nathan Vieux
Membro desde: 12/04/23
205 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 17
Ao todo: 135
