Ir para o conteúdo principal
K5 Desktop Humidifier Cotton Swab Filter Replacement
O que você precisa
  1. K5 Desktop Humidifier Cotton Swab Filter Replacement, Cotton Swab Filter: passo 1, imagem 1 %32
    • Press and hold the humidifier switch. Check whether the connection to the power supply still works.
    • The purpose is to rule out a power failure that would render the humidifier inoperable.
  2. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 2, imagem 1 %32
    • Use the spudger to slowly pry the middle part of the humidifier at the seam.
    • Be slow to open it, otherwise the humidifier outer body could be damaged.
  3. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 3, imagem 1 %32 K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 3, imagem 2 %32 K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 3, imagem 3 %32
    • Remove the cotton swab and spring from inside the humidifier.
  4. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 4, imagem 1 %32
    • Replace the old cotton swab filter with the new cotton swab.
  5. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 5, imagem 1 %32 K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 5, imagem 2 %32 K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 5, imagem 3 %32
    • Put the new cotton swab into the humidifier.
    • Hand tighten the part where the cotton swab and humidifier meet.
    • The picture shows how it looks when fully installed.
  6. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 6, imagem 1 %32
    • Reassemble the humidifier by snapping on the top half.
  7. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 7, imagem 1 %32
    • Plug in the power adaptor to your USB port to use.
Conclusão
YikunFang
Membro desde: 01/13/22
169 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 34
Duração total: 1,613
