Ir para o conteúdo principal
Justin Bieber Concert Microphone Speaker Replacement
O que você precisa
  1. Justin Bieber Concert Microphone Speaker Replacement, Removing back panel: passo 1, imagem 1 %32 Justin Bieber Concert Microphone Speaker Replacement, Removing back panel: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Flathead 1.5 mm Screwdriver
    $5.49
    Comprar
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Speaker Replacement, Removing batteries: passo 2, imagem 1 %32
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Speaker Replacement, Removing back half of device: passo 3, imagem 1 %32 Justin Bieber Concert Microphone Speaker Replacement, Removing back half of device: passo 3, imagem 2 %32
    • Unscrew the other 4, #8 11.5 mm Phillips head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Speaker Replacement, Positioning device: passo 4, imagem 1 %32
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Speaker Replacement, Removing speaker: passo 5, imagem 1 %32 Justin Bieber Concert Microphone Speaker Replacement, Removing speaker: passo 5, imagem 2 %32
    • Remove the 2, #8 11.7 mm speaker guard screws with the Phillips Head screw driver.
  6. Justin Bieber Concert Microphone Speaker Replacement, Replacing speaker: passo 6, imagem 1 %32
    • Disconnect the speaker wires from the speaker and replace it with the new one
    • Refer to this guide for help with soldering the wires back onto the speaker.
Conclusão
Mike Seyman
Membro desde: 10/19/14
437 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 4-1, Williams Fall 2014 Membro de Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 175
