Ir para o conteúdo principal
Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement
O que você precisa
  1. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back panel: passo 1, imagem 1 %32 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back panel: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Flathead 1.5 mm Screwdriver
    $5.49
    Comprar
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing batteries: passo 2, imagem 1 %32
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back half of device: passo 3, imagem 1 %32 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back half of device: passo 3, imagem 2 %32
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Positioning device: passo 4, imagem 1 %32
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Inspecting PCB: passo 5, imagem 1 %32
    • Inspect the printed circuit board for any breaks or cracks.
  6. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing PCB: passo 6, imagem 1 %32 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing PCB: passo 6, imagem 2 %32
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  7. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Replacing PCB: passo 7, imagem 1 %32 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Replacing PCB: passo 7, imagem 2 %32
    • Disconnect all wires from the PCB
    • Remove the damaged PCB from the microphone
    • Place new PCB in the Justin Bieber Concert Microphone.
    • Connect all the wires to the new PCB using this soldering guide.
Conclusão
Mike Seyman
Membro desde: 10/19/14
437 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 4-1, Williams Fall 2014 Membro de Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 289
