Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
The buttons on the Justin Bieber Concert Microphone allow the user to the choose between the two programmed songs and add concert noise. The user will know if the button is broken if the button does not perform as intended. Such as not being being able to stop the song or not being able to add the concert noise.
Peças
Nenhum componente especificado.
  1. Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device. Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Remove the 3 AAA batteries from the device.
    • Remove the 3 AAA batteries from the device.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device. Pull apart the device once screws are loose, splitting the device in half.
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  5. Keeping all wires connected to their attachments, place the front half of the device face down.
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  6. Remove the buttons by pushing them out from the front of the device. Clean or replace them as needed and place them back into the appropriate slots. Remove the buttons by pushing them out from the front of the device. Clean or replace them as needed and place them back into the appropriate slots.
    • Remove the buttons by pushing them out from the front of the device. Clean or replace them as needed and place them back into the appropriate slots.
Conclusão
Mike Seyman
Membro desde: 19-10-2014
425 Reputação
4 Guias de autoria
equipe
Baylor, Team 4-1, Williams Fall 2014 Membro de Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Membros
4 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 69
