Ir para o conteúdo principal
Justin Bieber Concert Microphone Button Replacement
O que você precisa
  1. Justin Bieber Concert Microphone Button Replacement, Removing back panel: passo 1, imagem 1 %32 Justin Bieber Concert Microphone Button Replacement, Removing back panel: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
    Pergunte ao FixBot
    Comentar
  2. Justin Bieber Concert Microphone Button Replacement, Removing batteries: passo 2, imagem 1 %32
    • Remove the 3 AAA batteries from the device.
    Pergunte ao FixBot
    Comentar
  3. Justin Bieber Concert Microphone Button Replacement, Removing back half of device: passo 3, imagem 1 %32 Justin Bieber Concert Microphone Button Replacement, Removing back half of device: passo 3, imagem 2 %32
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
    Pergunte ao FixBot
    Comentar
  4. Justin Bieber Concert Microphone Button Replacement, Positioning device: passo 4, imagem 1 %32
    • Keeping all wires connected to their attachments, place the front half of the device face down.
    Pergunte ao FixBot
    Comentar
  5. Justin Bieber Concert Microphone Button Replacement, Removing buttons: passo 5, imagem 1 %32 Justin Bieber Concert Microphone Button Replacement, Removing buttons: passo 5, imagem 2 %32
    • Remove the buttons by pushing them out from the front of the device. Clean or replace them as needed and place them back into the appropriate slots.
    Pergunte ao FixBot
    Comentar
Conclusão
Mike Seyman
Membro desde: 10/19/14
437 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 4-1, Williams Fall 2014 Membro de Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 33
Ao todo: 397
