Ir para o conteúdo principal
Jura Drainage valve (2)
O que você precisa
  1. Jura Drainage valve (2), Jura Drainage valve (2): passo 1, imagem 1 %32 Jura Drainage valve (2), Jura Drainage valve (2): passo 1, imagem 2 %32 Jura Drainage valve (2), Jura Drainage valve (2): passo 1, imagem 3 %32
    • The brewing group has already been removed and disassembled. Now it's time for the drainage valve.
    • There will be many pictures
    • All you need a small flathead screwdriver.
  2. Jura Drainage valve (2): passo 2, imagem 1 %32 Jura Drainage valve (2): passo 2, imagem 2 %32 Jura Drainage valve (2): passo 2, imagem 3 %32
    • Images front and back
  3. Jura Drainage valve (2): passo 3, imagem 1 %32 Jura Drainage valve (2): passo 3, imagem 2 %32 Jura Drainage valve (2): passo 3, imagem 3 %32
    • Pull off the clamp and pull out the inlet hose. At the end there is a seal, it often gets stuck in the drainage valve. Swap them out when reassembling.
  4. Jura Drainage valve (2): passo 4, imagem 1 %32 Jura Drainage valve (2): passo 4, imagem 2 %32 Jura Drainage valve (2): passo 4, imagem 3 %32
    • Pull out the clip on the docking tube
    • Pry out the valve body. Make sure the white cap slides out of its hole.
    • Detach the docking nozzle.
  5. Jura Drainage valve (2): passo 5, imagem 1 %32 Jura Drainage valve (2): passo 5, imagem 2 %32 Jura Drainage valve (2): passo 5, imagem 3 %32
    • Detailed photos.
    • The position of the sealing rings are marked green in picture 3.
    • The sealing ring on the docking socket is marked in red in picture 2. It is especially important. It's a little thinner than the other two.
    • The brackets are marked in red.
  6. Jura Drainage valve (2): passo 6, imagem 1 %32 Jura Drainage valve (2): passo 6, imagem 2 %32 Jura Drainage valve (2): passo 6, imagem 3 %32
    • Here all the parts of the valve.
  7. Jura Drainage valve (2): passo 7, imagem 1 %32
    • Here is the entire valve in one picture
  8. Jura Drainage valve (2): passo 8, imagem 1 %32 Jura Drainage valve (2): passo 8, imagem 2 %32 Jura Drainage valve (2): passo 8, imagem 3 %32
    • Reassembly
    • When assembling, make sure that the lips of the seals point to the pressure side, i.e. inward, and the flat side outward.
    • When installing, make sure that the pressure hose runs through the slot in the valve carrier.
Conclusão
Follow the steps in reverse order to reassemble your device.
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Schwarzstein
Membro desde: 07/15/13
2.813 Reputação
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 33
Últimos 30 dias: 210
Duração total: 7,964
