Ir para o conteúdo principal
Jumper EZbook S5 Touchpad Replacement
O que você precisa
  1. Jumper EZbook S5 Touchpad Replacement, Touchpad: passo 1, imagem 1 %32 Jumper EZbook S5 Touchpad Replacement, Touchpad: passo 1, imagem 2 %32
    • Place the laptop so the bottom is facing upwards.
    • Remove the two 8 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the three 5 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the six 4 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the single 3 mm base screw inside the battery case using a T3 Torx screwdriver.
  2. Jumper EZbook S5 Touchpad Replacement: passo 2, imagem 1 %32 Jumper EZbook S5 Touchpad Replacement: passo 2, imagem 2 %32 Jumper EZbook S5 Touchpad Replacement: passo 2, imagem 3 %32
    • Detach the battery case using the flat end of a spudger.
  3. Jumper EZbook S5 Touchpad Replacement: passo 3, imagem 1 %32 Jumper EZbook S5 Touchpad Replacement: passo 3, imagem 2 %32 Jumper EZbook S5 Touchpad Replacement: passo 3, imagem 3 %32
    • Pry apart the bottom cover of the laptop using the flat end of a spudger.
  4. Jumper EZbook S5 Touchpad Replacement: passo 4, imagem 1 %32 Jumper EZbook S5 Touchpad Replacement: passo 4, imagem 2 %32 Jumper EZbook S5 Touchpad Replacement: passo 4, imagem 3 %32
    • Remove the four 4 mm screws from the battery using a T3 Torx screwdriver.
  5. Jumper EZbook S5 Touchpad Replacement: passo 5, imagem 1 %32 Jumper EZbook S5 Touchpad Replacement: passo 5, imagem 2 %32 Jumper EZbook S5 Touchpad Replacement: passo 5, imagem 3 %32
    • Flip the battery to the opposite side of the touchpad.
  6. Jumper EZbook S5 Touchpad Replacement: passo 6, imagem 1 %32 Jumper EZbook S5 Touchpad Replacement: passo 6, imagem 2 %32 Jumper EZbook S5 Touchpad Replacement: passo 6, imagem 3 %32
    • Detach the tape on the left side of the touchpad shown in the first two images.
    • Use a heat gun or a hair dryer to melt the glue quickly.
  7. Jumper EZbook S5 Touchpad Replacement: passo 7, imagem 1 %32 Jumper EZbook S5 Touchpad Replacement: passo 7, imagem 2 %32 Jumper EZbook S5 Touchpad Replacement: passo 7, imagem 3 %32
    • Detach the tape on the right side of the touchpad shown in all three images.
    • Use a hair dryer or a heat gun to soften the glue.
  8. Jumper EZbook S5 Touchpad Replacement: passo 8, imagem 1 %32 Jumper EZbook S5 Touchpad Replacement: passo 8, imagem 2 %32 Jumper EZbook S5 Touchpad Replacement: passo 8, imagem 3 %32
    • Use a spudger to detach the touchpad from the top case.
    • The touchpad is attached to the top case with glue. Use a hair dryer or a heat gun to soften the glue.
    • Be patient. Step 8 can take up to 8 hours if you work by yourself.
    • Don't aim the heat gun or the hair dryer anywhere other than the top case.
  9. Jumper EZbook S5 Touchpad Replacement: passo 9, imagem 1 %32 Jumper EZbook S5 Touchpad Replacement: passo 9, imagem 2 %32 Jumper EZbook S5 Touchpad Replacement: passo 9, imagem 3 %32
    • Lift the touchpad out of the case.
Conclusão
Zed Chen
Membro desde: 10/25/22
223 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 60
Duração total: 1,316
