Ir para o conteúdo principal
Jumper Angelsounds JPD-100S The Transducer Replacement
O que você precisa
  1. Jumper Angelsounds JPD-100S The Transducer  Replacement, Motherboard: passo 1, imagem 1 %32
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 2, imagem 1 %32 Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 2, imagem 2 %32
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 3, imagem 1 %32
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 4, imagem 1 %32 Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 4, imagem 2 %32
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 5, imagem 1 %32 Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 5, imagem 2 %32
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 6, imagem 1 %32
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 7, imagem 1 %32
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S The Transducer  Replacement, The Transducer: passo 8, imagem 1 %32
    • Unsolder the Black cable
  9. Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 9, imagem 1 %32 Jumper Angelsounds JPD-100S The Transducer  Replacement: passo 9, imagem 2 %32
    • Unsolder the red cables from the metal plates.
Conclusão
Muosa Almubarak
Membro desde: 09/29/15
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 6-1, Remmell Fall 2015 Membro de USF Tampa, Team 6-1, Remmell Fall 2015
USFT-REMMELL-F15S6G1
Membros da 6
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 300
