Ir para o conteúdo principal
Jumper Angelsounds JPD-100S Headphone Jacks Replacement
O que você precisa
  1. Jumper Angelsounds JPD-100S Headphone Jacks Replacement, Motherboard: passo 1, imagem 1 %32
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 2, imagem 1 %32 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 2, imagem 2 %32
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 3, imagem 1 %32
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 4, imagem 1 %32 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 4, imagem 2 %32
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 5, imagem 1 %32 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 5, imagem 2 %32
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 6, imagem 1 %32
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 7, imagem 1 %32
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Headphone Jacks Replacement, Headphone Jacks: passo 8, imagem 1 %32
    • Take the battery connector out of the battery compartment.
  9. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 9, imagem 1 %32
    • Preheat the soldering iron .
    • Locate the wires that connect to the transducer.
    • Use a soldering iron and solder vacuum to unsolder the wires connected to the transducer.
  10. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 10, imagem 1 %32 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 10, imagem 2 %32
    • Place the motherboard in a position that allows easy access to the jacks.
  11. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 11, imagem 1 %32 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 11, imagem 2 %32 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 11, imagem 3 %32
    • Desolder the three solder joints securing each of the headphone jacks.
    • Try not to melt the motherboard when removing solder that secures the jacks.
  12. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: passo 12, imagem 1 %32
    • Remove the jacks by pulling them out of the motherboard.
Conclusão
Yessika Lugo
Membro desde: 08/31/15
113 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 6-1, Remmell Fall 2015 Membro de USF Tampa, Team 6-1, Remmell Fall 2015
USFT-REMMELL-F15S6G1
Membros da 6
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 370
