Ir para o conteúdo principal
Jensen JTA-230 Volume Knob Replacement
  1. Jensen JTA-230 Volume Knob Replacement, Volume Knob: passo 1, imagem 1 %32
    • Carefully place on a table where it will hold a lot of pressure
  2. Jensen JTA-230 Volume Knob Replacement: passo 2, imagem 1 %32
    • Next, using your thumb and finger, get a good grasp on the volume knob, and carefully but forcefully pull on it and it will pop off.
  3. Jensen JTA-230 Volume Knob Replacement: passo 3, imagem 1 %32
    • Next, take your new volume knob and simply pop it back into place the same way you took the old one off, and you are good to go.
Conclusão
Equipe
UMass Dartmouth, Team 8-8, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-8, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G8
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 454
