Ir para o conteúdo principal
Jensen JTA-230 Turntable Platter Replacement
O que você precisa
  1. Jensen JTA-230 Turntable Platter Replacement, Turntable Platter: passo 1, imagem 1 %32
    • Remove Cover from record player.
  2. Jensen JTA-230 Turntable Platter Replacement: passo 2, imagem 1 %32
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Turntable Platter Replacement: passo 3, imagem 1 %32
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Turntable Platter Replacement: passo 4, imagem 1 %32
    • Replace rubber plugs
  5. Jensen JTA-230 Turntable Platter Replacement: passo 5, imagem 1 %32
    • Replace Cover
Conclusão
Robert Wilcox
Membro desde: 03/04/16
227 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 8-8, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-8, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G8
Membros da 3
Autoria de 5 guias
Um comentário
There's an important step missing here in that there is a "C" clip on the center pin that you need to remove. Also, this does not include how to replace the belt onto the motor, which is vital in restoring how a record player functions. Can you please update with this information?
ironman175 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 1,642
