Ir para o conteúdo principal
Jensen JTA-230 Motor Replacement
O que você precisa
  1. Jensen JTA-230 Motor Replacement, Turntable Platter: passo 1, imagem 1 %32
    • Remove Cover from record player.
  2. Jensen JTA-230 Motor Replacement: passo 2, imagem 1 %32
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Motor Replacement: passo 3, imagem 1 %32
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Motor Replacement: passo 4, imagem 1 %32
    • Replace rubber plugs
  5. Jensen JTA-230 Motor Replacement: passo 5, imagem 1 %32
    • Replace Cover
  6. Jensen JTA-230 Motor Replacement, Motor: passo 6, imagem 1 %32 Jensen JTA-230 Motor Replacement, Motor: passo 6, imagem 2 %32
    • After removal of the turntable platter, 3 small screws can be seen. Remove the 3 screws which hold the motor in place.
    • On both the right and left side, there are 3 screws, remove each of them.
  7. Jensen JTA-230 Motor Replacement: passo 7, imagem 1 %32 Jensen JTA-230 Motor Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently Pull the top off of the sides and flip over to reveal the circuitry.
    • To remove the top entirely, remove each electrical connection with a pair of tweezers. There are 3, each connecting to the speakers.
  8. Jensen JTA-230 Motor Replacement: passo 8, imagem 1 %32
    • Remove the Motor from the record player
    • Using a soldering iron, remove the motor from the circuitry.
    • Replace motor with new one.
Conclusão
Robert Wilcox
Membro desde: 03/04/16
227 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 8-8, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-8, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G8
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 1,995
