Ir para o conteúdo principal
Jazz UltraTab C1059-HL Speaker Replacement
O que você precisa
  1. Jazz UltraTab C1059-HL Speaker Replacement, Speaker: passo 1, imagem 1 %32 Jazz UltraTab C1059-HL Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Start by removing the back panel.
    • Remove the 4 screws holding the device together: two on the left side, and two on the right side.
    • Using a metal spudger, carefully pry open the case.
    • With the screws gone, the case is held together with clips along the outside edge of the aluminum backplate.
    • Undoing these clips can take a bit of force. Be cautious not to damage the plastic edge of the device.
  2. Jazz UltraTab C1059-HL Speaker Replacement: passo 2, imagem 1 %32
    • Place the device on the table with the screen-side down.
  3. Jazz UltraTab C1059-HL Speaker Replacement: passo 3, imagem 1 %32
    • This is the Speaker.
    • Remove the two black screws.
  4. Jazz UltraTab C1059-HL Speaker Replacement: passo 4, imagem 1 %32
    • Remove black tape from the wires.
    • Keep this tape, you will need it for reassembly.
  5. Jazz UltraTab C1059-HL Speaker Replacement: passo 5, imagem 1 %32
    • Using a soldering iron, heat up the spot where the speaker wires connect to the mainboard.
    • Remove Speaker wires when the solder liquifies.
    • Remember to make note of where each wire is connected. When reinstalling the speaker, it is important that the wires are reattached to the same spot.
  6. Jazz UltraTab C1059-HL Speaker Replacement: passo 6, imagem 1 %32
    • Remove the speaker.
    • Replace the speaker by following these steps in reverse.
Conclusão
Uma outra pessoa concluiu este guia.
Tim Poe
Membro desde: 09/26/15
361 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-3, Wilson Fall 2015 Membro de IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 95
