Ir para o conteúdo principal
Jazz UltraTab C1059-HL Screen Replacement
O que você precisa
  1. Jazz UltraTab C1059-HL Screen Replacement, Screen: passo 1, imagem 1 %32
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Screen Replacement: passo 2, imagem 1 %32
    • Remove the back panel of the device.
    • Be careful not to brake/bend the plastic cover of your device.
  3. Jazz UltraTab C1059-HL Screen Replacement: passo 3, imagem 1 %32
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Screen Replacement: passo 4, imagem 1 %32
    • Remove all data strips attached to the motherboard.
  5. Jazz UltraTab C1059-HL Screen Replacement: passo 5, imagem 1 %32 Jazz UltraTab C1059-HL Screen Replacement: passo 5, imagem 2 %32 Jazz UltraTab C1059-HL Screen Replacement: passo 5, imagem 3 %32
    • Remove the tape around the battery.
    • One of these pieces of tape holds down the battery connection to the mainboard.
    • Use the soldering iron to disconnect these wires.
    • You will need to use a tool to pry off the battery. It will have a good amount of adhesive holding it down.
    • Be cautious not to bend the battery when prying.
  6. Jazz UltraTab C1059-HL Screen Replacement: passo 6, imagem 1 %32
    • Once the battery is removed, make sure to remove any and all data strips that are attached.
    • Then begin to unscrew the mother board.
  7. Jazz UltraTab C1059-HL Screen Replacement: passo 7, imagem 1 %32
    • Remove the motherboard chip off of the device.
  8. Jazz UltraTab C1059-HL Screen Replacement: passo 8, imagem 1 %32
    • Your board should look like this after taking all of the components off the screen panel.
  9. Jazz UltraTab C1059-HL Screen Replacement: passo 9, imagem 1 %32 Jazz UltraTab C1059-HL Screen Replacement: passo 9, imagem 2 %32
    • Remove the Display Module from the screen cover.
  10. Jazz UltraTab C1059-HL Screen Replacement: passo 10, imagem 1 %32
    • Now, you can replace your broken or damaged screen!
Conclusão
Uma outra pessoa concluiu este guia.
Amanda Justiniano
Membro desde: 09/19/15
231 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-3, Wilson Fall 2015 Membro de IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 450
