Ir para o conteúdo principal
Jazz UltraTab C1059-HL Battery Replacement
O que você precisa
  1. Jazz UltraTab C1059-HL Battery Replacement, Battery: passo 1, imagem 1 %32
    • remove the screws at the four corners of the device.
  2. Jazz UltraTab C1059-HL Battery Replacement: passo 2, imagem 1 %32 Jazz UltraTab C1059-HL Battery Replacement: passo 2, imagem 2 %32
    • Use a prying tool to pry the back panel from the tablet chassis. Pry the panel at different locations around the device to separate clips.
  3. Jazz UltraTab C1059-HL Battery Replacement: passo 3, imagem 1 %32
    • Use a soldering iron to remove power cables from battery. The power cable is shown at the corner of the battery in the picture.
  4. Jazz UltraTab C1059-HL Battery Replacement: passo 4, imagem 1 %32 Jazz UltraTab C1059-HL Battery Replacement: passo 4, imagem 2 %32
    • Use a tool to carefully pry battery away from chassis. The battery is attached by an adhesive. Slowly pry battery on the side away from the motherboard.
  5. Jazz UltraTab C1059-HL Battery Replacement: passo 5, imagem 1 %32
    • You have successfully removed the battery. Put new battery in the same location. Solder the supply wires. Reapply tape in original location.
Conclusão
Austen Shields
Membro desde: 09/26/15
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-3, Wilson Fall 2015 Membro de IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 594
