Ir para o conteúdo principal
Jazz UltraTab C1059-HL Antenna Replacement
O que você precisa
  1. Jazz UltraTab C1059-HL Antenna Replacement, Antenna: passo 1, imagem 1 %32
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Antenna Replacement: passo 2, imagem 1 %32
    • Remove the back panel of the device.
  3. Jazz UltraTab C1059-HL Antenna Replacement: passo 3, imagem 1 %32
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Antenna Replacement: passo 4, imagem 1 %32
    • Identify the antenna cover on the top of the device.
  5. Jazz UltraTab C1059-HL Antenna Replacement: passo 5, imagem 1 %32
    • Remove the two screws holding the antenna cover in place.
  6. Jazz UltraTab C1059-HL Antenna Replacement: passo 6, imagem 1 %32
    • Use a prying tool to remove the plastic piece off of the antenna component.
  7. Jazz UltraTab C1059-HL Antenna Replacement: passo 7, imagem 1 %32
    • Identify the antenna component as the gray cable that comes out of the plastic cover.
  8. Jazz UltraTab C1059-HL Antenna Replacement: passo 8, imagem 1 %32
    • Remove all of the adhesive tape pieces off of the antenna cable.
  9. Jazz UltraTab C1059-HL Antenna Replacement: passo 9, imagem 1 %32
    • Once all of the adhesive tape has been removed. Pull out the antenna component.
  10. Jazz UltraTab C1059-HL Antenna Replacement: passo 10, imagem 1 %32
    • The antenna will be attached to the chip in your device. Be careful not to pull off.
    • Solder of the wire that is connected to the chip in order to be able to remove the antenna component.
    • Once this is done, you can replace your old antenna with a new one!
Conclusão
Amanda Justiniano
Membro desde: 09/19/15
231 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-3, Wilson Fall 2015 Membro de IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 196
