Ir para o conteúdo principal
Jawbone MINI JAMBOX Outer Case Replacement
O que você precisa
  1. Jawbone MINI JAMBOX Outer Case Replacement, Outer Case: passo 1, imagem 1 %32 Jawbone MINI JAMBOX Outer Case Replacement, Outer Case: passo 1, imagem 2 %32
    • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
    I was able to remove the cover without cosmetic damage. I used a 6” sharp knife blade, slid it into the crack and twisted. As Kevin states in Step 2, you are trying to lift up the center of the long edge. The top short end has two tabs and the bottom end has one big tab in the center.
    Student4Life - Responder
    Yes I agree with Student4Life. Just insert the spudger into the top short edge (the edge without rubber foot) and you can remove the cover without noteble damage.
    Leon - Responder
  2. Jawbone MINI JAMBOX Outer Case Replacement: passo 2, imagem 1 %32
    • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
    • Carefully remove the end panel.
    • The tabs which connect the panel are on the short sides.
    • WARNING: you will likely cause cosmetic damage to the end cap.
  3. Jawbone MINI JAMBOX Outer Case Replacement: passo 3, imagem 1 %32
    • Slide out the rubber foot located on the bottom of the case.
  4. Jawbone MINI JAMBOX Outer Case Replacement: passo 4, imagem 1 %32
    • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
    • This is the only flat topped screw in the speaker, so keep track of which one it is.
    I didn’t have a T6 bit. My set only went down to T7. I was able to seat a jeweler’s flat-blade screwdriver into the head, press down firmly, and turn the screw head. Even after breaking the screw loose, there was significant drag to turn it, so be careful of the tool slipping out of the screw head.
  5. Jawbone MINI JAMBOX Outer Case Replacement: passo 5, imagem 1 %32 Jawbone MINI JAMBOX Outer Case Replacement: passo 5, imagem 2 %32 Jawbone MINI JAMBOX Outer Case Replacement: passo 5, imagem 3 %32
    • Push against the side without end cap to slide the internal components out of the case.
    • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
    • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
Conclusão
Uma outra pessoa concluiu este guia.
Noah Sadler
Membro desde: 04/01/15
548 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 12-1, Lancaster Spring 2015 Membro de Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
Membros da 5
Autoria de 11 guias
Um comentário
Does anyone know where to find replacement outer shells for the big jambox?
aric.valliere - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 3,202
