Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
While this guide is essential to replacing many parts on the Jawbone MINI JAMBOX, it requires an advanced level of technical knowledge. Only attempt to remove the motherboard if it is absolutely necessary.
O que você precisa
Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
Remove all connecting ribbons from the motherboard.
One ZIF or "zero insertion force" ribbon connecting at the side.
One standard ribbon connector in the middle (Note: this ZIF ribbon is lightly glued to the surface).
6 outras pessoas executaram este guia.
