Introdução
If your speaker is not working, it may need to be replaced. This guide requires having a new, compatible speaker to replace the broken one with.
O que você precisa
Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
Remove the three T6, 7.0 mm screws under each rubber tab.
I used rubber cement to reattach the pads. That will hold them in place and be easily removable in future.
With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
Unscrew indicated T6 9.7 mm screws.
Gently loosen the tabs from their anchor points so the bottom may be removed.
Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
Pry up the bottom panel by lifting from the device.
Pull the bottom up. This may take a bit of force as the bottom is glued to device.
Once removed, the battery will now be visible.
Place the disassembled Jambox with the speakers facing up.
Locate the screws around the broken speaker.
Use a T15 screwdriver to remove the four 12.1 mm screws around the broken speaker.
Desolder the wires from the speaker terminal in the Jambox.
Fine, but where did you buy the new speaker ? I can’t find it.
Fabrizio
I’d like to know the speaker capacity or specifications in ohms and watts. If someone know I’ll really appreciate.
12 outras pessoas executaram este guia.
14 comentários
What is actual original speaker size and watts power?
Eu também gostaria de saber qual a potência e o tamanho exato do falante original para substituí-lo
I would also like to know the power and the exact size of the original speaker to replace it
Does anyone know where to buy replacement speakers or for which they can be switched?
@ Oliver,
I just wasted a pair of speakers because you mentioned those worked just fine for you. They are not the same sizes. it's smaller than the jamb speakers... On what basis you made that comment?
does anyone know where to buy replacement parts - looking for the outer metal shell as it’s dented. thanks
What are the symptoms of the problems you guys are having?
Why do you think the speakers are the problem, and not the electronic amplifier?
Mine is sounding bad, and I’m pretty sure it’s from blown amplifier transistors, not the speakers…
How do I know it’s the amplifier and not the speaker? Where can I find these parts for my jawbone jam box? Thank you anyone please?!
Many Years later, but... speakers are rectangular frame 56mm wide, screw holes 46mm.
Model: 130-00028
Found a company in Germany selling them, so i ordered and will see later.
hope it helped someone
https://oaudio.de/LAVOCE-FSN02071-2-full....
Not exact model but very very similar.
I will try them.
Thanks for reviving the thread!
did you note the ohms and watt rating?
If I search the speaker model number I get some choices on Amazon.
Cheers
2pcs 4ohm 8ohm speaker 2 inch Full Range Speaker Portable Speakers 10W 15W 20W Loudspeaker DIY HIFI BT Speakers(8ohm 20W) https://amzn.eu/d/aClOCl0
Can someone show the clips please in a photo?
kenneth keen - Responder
