Ir para o conteúdo principal
Jawbone Big Jambox Speaker Replacement
O que você precisa
  1. Jawbone Big Jambox Speaker Replacement, Outer Case: passo 1, imagem 1 %32
    • Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
    • Due to interior clips holding the end caps in place, use caution when applying force.
    Can someone show the clips please in a photo?
    kenneth keen - Responder
  2. Jawbone Big Jambox Speaker Replacement: passo 2, imagem 1 %32 Jawbone Big Jambox Speaker Replacement: passo 2, imagem 2 %32 Jawbone Big Jambox Speaker Replacement: passo 2, imagem 3 %32
    • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
    • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
    • Remove the three T6, 7.0 mm screws under each rubber tab.
    • Because the screws are a different length, set the screws aside.
    I used rubber cement to reattach the pads. That will hold them in place and be easily removable in future.
    David Robinson - Responder
  3. Jawbone Big Jambox Speaker Replacement: passo 3, imagem 1 %32 Jawbone Big Jambox Speaker Replacement: passo 3, imagem 2 %32 Jawbone Big Jambox Speaker Replacement: passo 3, imagem 3 %32
    • With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
    • Unscrew indicated T6 9.7 mm screws.
    • Gently loosen the tabs from their anchor points so the bottom may be removed.
    • Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
  4. Jawbone Big Jambox Speaker Replacement: passo 4, imagem 1 %32
    • Pry up the bottom panel by lifting from the device.
    • Pull the bottom up. This may take a bit of force as the bottom is glued to device.
    • Once removed, the battery will now be visible.
    No glue on mine. Only two clips on each side (that you can see clearly in step 3 picture).
    Do not use force or you will break those clips.
    Jay - Responder
  5. Jawbone Big Jambox Speaker Replacement: passo 5, imagem 1 %32 Jawbone Big Jambox Speaker Replacement: passo 5, imagem 2 %32
    • Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates.
    • Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
  6. Jawbone Big Jambox Speaker Replacement: passo 6, imagem 1 %32
    • Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
  7. Jawbone Big Jambox Speaker Replacement: passo 7, imagem 1 %32
    • With the battery facing forward, remove the three indicated T6 9.5 mm screws.
    • Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
  8. Jawbone Big Jambox Speaker Replacement, Speaker: passo 8, imagem 1 %32 Jawbone Big Jambox Speaker Replacement, Speaker: passo 8, imagem 2 %32 Jawbone Big Jambox Speaker Replacement, Speaker: passo 8, imagem 3 %32
    • Place the disassembled Jambox with the speakers facing up.
    • Locate the screws around the broken speaker.
    • Use a T15 screwdriver to remove the four 12.1 mm screws around the broken speaker.
  9. Jawbone Big Jambox Speaker Replacement: passo 9, imagem 1 %32
    • Using a plastic opening tool, pry the speaker out of the Jambox.
  10. Jawbone Big Jambox Speaker Replacement: passo 10, imagem 1 %32 Jawbone Big Jambox Speaker Replacement: passo 10, imagem 2 %32
    • Desolder the wires from the speaker terminal in the Jambox.
    • Detach the round speaker from its square frame, and save the square frame for the replacement speaker.
    • Use caution when operating a soldering iron due to extreme heat.
    • For instructions on how to solder and desolder, take a look at the soldering guide.
    Pessoal bom dia , onde consigo comprar o Auto Falante ?
    ronin496 - Responder
    Fine, but where did you buy the new speaker ? I can’t find it.
    Fabrizio
    Fabrizio Dell'Anese - Responder
    I’d like to know the speaker capacity or specifications in ohms and watts. If someone know I’ll really appreciate.
    Benjamin Hernandez - Responder
Conclusão
12 outras pessoas executaram este guia.
Taryn Kelley
Membro desde: 04/01/15
672 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 24-5, Lancaster Spring 2015 Membro de Cal Poly, Team 24-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G5
Membros da 4
Autoria de 9 guias
14 comentários
What is actual original speaker size and watts power?
Phinlander Betancur - Responder
Eu também gostaria de saber qual a potência e o tamanho exato do falante original para substituí-lo
I would also like to know the power and the exact size of the original speaker to replace it
francisnvieira - Responder
Does anyone know where to buy replacement speakers or for which they can be switched?
olivierdegruijter - Responder
@ Oliver,
I just wasted a pair of speakers because you mentioned those worked just fine for you. They are not the same sizes. it's smaller than the jamb speakers... On what basis you made that comment?
Kaveh Kadkhoda Zadeh - Responder
bought mine (2 speakers x $18 bucks) replaced both and now is working and even louder. not gonna lie I had to cut on one side of the box where the speaker fits in but after ding it so and soldering the speakers now is working.
karloznyf - Responder
does anyone know where to buy replacement parts - looking for the outer metal shell as it’s dented. thanks
aric.valliere - Responder
What are the symptoms of the problems you guys are having?
Why do you think the speakers are the problem, and not the electronic amplifier?
Mine is sounding bad, and I’m pretty sure it’s from blown amplifier transistors, not the speakers…
Chris Drake - Responder
hello chis drake, can u buy new amplifier transistors, and what make u think its not the speaker!?
wi dekker - Responder
How do I know it’s the amplifier and not the speaker? Where can I find these parts for my jawbone jam box? Thank you anyone please?!
Juanita Diaz - Responder
Informative disassembly tips.
Problem is……..
What speakers to use for replacements.
Please give dimensions, height and magnet size.
Wattage and ohms.
Thank You
BoB - Responder
Many Years later, but... speakers are rectangular frame 56mm wide, screw holes 46mm.
Model: 130-00028
Found a company in Germany selling them, so i ordered and will see later.
hope it helped someone
Sean Booth - Responder
https://oaudio.de/LAVOCE-FSN02071-2-full....
Not exact model but very very similar.
I will try them.
Sean Booth -
Thanks for reviving the thread!
did you note the ohms and watt rating?
If I search the speaker model number I get some choices on Amazon.
Cheers
2pcs 4ohm 8ohm speaker 2 inch Full Range Speaker Portable Speakers 10W 15W 20W Loudspeaker DIY HIFI BT Speakers(8ohm 20W) https://amzn.eu/d/aClOCl0
Jamie Little -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 58
Duração total: 22,685
