Ir para o conteúdo principal
Jam Voice Battery Replacement
O que você precisa
  1. Jam Voice Battery Replacement, Hard Mesh Cover: passo 1, imagem 1 %32 Jam Voice Battery Replacement, Hard Mesh Cover: passo 1, imagem 2 %32
    • Insert the plastic opening tool underneath the mesh top.
    • Pry the cover open.
    • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
  2. Jam Voice Battery Replacement, Motherboard: passo 2, imagem 1 %32
    • Remove the four 7mm Phillips screws from the plastic cover.
  3. Jam Voice Battery Replacement: passo 3, imagem 1 %32 Jam Voice Battery Replacement: passo 3, imagem 2 %32
    • Remove the four 5mm Phillips screws that hold down the speaker in place.
    • Remove the two 6mm Phillips screws that hold down the plastic casing.
  4. Jam Voice Battery Replacement: passo 4, imagem 1 %32
    • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
    • Pull the speaker up and out.
  5. Jam Voice Battery Replacement: passo 5, imagem 1 %32 Jam Voice Battery Replacement: passo 5, imagem 2 %32 Jam Voice Battery Replacement: passo 5, imagem 3 %32
    • Remove the four 7mm Phillips screws to expose the motherboard.
  6. Jam Voice Battery Replacement: passo 6, imagem 1 %32
    • After removing all of the screws from the plastic cover, remove it by pulling up and out.
    • Be careful not to pull and damage any of the wires.
  7. Jam Voice Battery Replacement: passo 7, imagem 1 %32 Jam Voice Battery Replacement: passo 7, imagem 2 %32
    • Remove the three 5mm Phillips screws that hold the motherboard in place.
    • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
  8. Jam Voice Battery Replacement, Battery: passo 8, imagem 1 %32 Jam Voice Battery Replacement, Battery: passo 8, imagem 2 %32 Jam Voice Battery Replacement, Battery: passo 8, imagem 3 %32
    • Expose the motherboard and battery and place in a position that will be easy to access and work with.
    • Use tweezers to remove the battery's wire from the motherboard at the connection point.
    • The battery's connection point is opposite the speaker's connection point.
    • Pull the battery from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 560
