Ir para o conteúdo principal
Jabra Elite 85h Microphone Replacement
O que você precisa
  1. Jabra Elite 85h Microphone Replacement, Ear Cushion: passo 1, imagem 1 %32 Jabra Elite 85h Microphone Replacement, Ear Cushion: passo 1, imagem 2 %32 Jabra Elite 85h Microphone Replacement, Ear Cushion: passo 1, imagem 3 %32
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Microphone Replacement, Speaker: passo 2, imagem 1 %32 Jabra Elite 85h Microphone Replacement, Speaker: passo 2, imagem 2 %32 Jabra Elite 85h Microphone Replacement, Speaker: passo 2, imagem 3 %32
    • The foam inserts and backing tape are very delicate. Take your time when removing them, and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Microphone Replacement: passo 3, imagem 1 %32 Jabra Elite 85h Microphone Replacement: passo 3, imagem 2 %32 Jabra Elite 85h Microphone Replacement: passo 3, imagem 3 %32
    • Repeat the previous steps for the other side, removing the foam inserts with care.
  4. Jabra Elite 85h Microphone Replacement: passo 4, imagem 1 %32
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Microphone Replacement: passo 5, imagem 1 %32
    • Repeat the previous step for the other side, removing the four T6 screws.
  6. Jabra Elite 85h Microphone Replacement: passo 6, imagem 1 %32
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
  7. Jabra Elite 85h Microphone Replacement, Microphone: passo 7, imagem 1 %32 Jabra Elite 85h Microphone Replacement, Microphone: passo 7, imagem 2 %32
    • Remove the four screws attaching the circuit boards to the headphone enclosure.
    • The microphone is located on the lower circuit board.
  8. Jabra Elite 85h Microphone Replacement: passo 8, imagem 1 %32 Jabra Elite 85h Microphone Replacement: passo 8, imagem 2 %32 Jabra Elite 85h Microphone Replacement: passo 8, imagem 3 %32
    • Remove the circuit boards from the headphone enclosure.
    • Carefully lift the bar located on the lower circuit board that contains the 24-pin ribbon cable. Remove the cable.
Conclusão
If the microphone on your Jabra Elite 85h is not working, replacement could be an appropriate solution.
Ryan Callaghan
Membro desde: 03/13/23
693 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 3-4, Petersen Spring 2023 Membro de UMass Dartmouth, Team 3-4, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G4
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 69
Duração total: 676
