Ir para o conteúdo principal
Jabra Elite 85h Bluetooth Module Replacement
O que você precisa
  1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: passo 1, imagem 1 %32 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: passo 1, imagem 2 %32 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: passo 1, imagem 3 %32
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Bluetooth Module Replacement: passo 2, imagem 1 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 2, imagem 2 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 2, imagem 3 %32
    • The foam inserts and backing tape are very delicate, take your time when removing them and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Bluetooth Module Replacement: passo 3, imagem 1 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 3, imagem 2 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 3, imagem 3 %32
    • Repeat previous steps on other side.
  4. Jabra Elite 85h Bluetooth Module Replacement: passo 4, imagem 1 %32
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Bluetooth Module Replacement: passo 5, imagem 1 %32
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
  6. Jabra Elite 85h Bluetooth Module Replacement: passo 6, imagem 1 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 6, imagem 2 %32
    • Remove the two screws holding the upper and lower circuit boards in place.
  7. Jabra Elite 85h Bluetooth Module Replacement: passo 7, imagem 1 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 7, imagem 2 %32
    • Remove the two attached circuit boards from the headphone housing.
    • De-solder Bluetooth Module from control board to replace.
Conclusão
Ryan Callaghan
Membro desde: 03/13/23
962 Reputação
Autoria de 4 guias
Equipe
2Comentários do guia
But where could one get this Bluetooth Module? Is it only available for Jabra workers?
sarita sulkakoski - Responder
Anyone can tell how I can get parts for this thing - need main module
Janusz Pokorski (Smartthing) - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 59
Ao todo: 2,294
