Ir para o conteúdo principal
JYX-S55 Battery Replacement
O que você precisa
  1. JYX-S55 Battery Replacement, Battery: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the six screws around the perimeter of the top panel of the machine using a 2.5 mm flathead screwdriver.
    Pergunte ao FixBot
    Comentar
  2. JYX-S55 Battery Replacement: passo 2, imagem 1 %32
    • Grip the top panel with your thumb at the bottom and fingers around the top. Lift the panel until it comes loose.
    Pergunte ao FixBot
    Comentar
  3. JYX-S55 Battery Replacement: passo 3, imagem 1 %32 JYX-S55 Battery Replacement: passo 3, imagem 2 %32
    • Move the top panel backwards and away from you. Let the panel hang down behind the machine, as this will allow you to have access to the components within the machine.
    Pergunte ao FixBot
    Comentar
  4. JYX-S55 Battery Replacement: passo 4, imagem 1 %32
    • Use a nylon spudger to pry the battery free from the glue.
    • It is important to note do NOT use heat or sharp objects, as the lithium-ion battery is flammable and could potentially explode.
    Pergunte ao FixBot
    Comentar
  5. JYX-S55 Battery Replacement: passo 5, imagem 1 %32
    • Disconnect the red and black wires from the battery.
    • Remove the battery from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Sarah Iceman
Membro desde: 02/24/23
502 Reputação
Autoria de 2 guias
Equipe
Marist, Team 1-5, Chaterdon Spring 2023 Membro de Marist, Team 1-5, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G5
3 Membros
Autoria de 4 guias
3Comentários do guia
Hi, thanks for the pictures that really helped. What type of battery is needed? Can you email me at vrhaiza@gmail.com.
Rhaiza Villafranca - Responder Compartilhar
Can you please advise what type of battery would be needed? What if I don't have a nylon spudger? What can I use in exchange?
Jasmine - Responder Compartilhar
I opened the Karaoke machine:
Lithium-ion
Type- Lithium-ion Battery
Capacity: 3.7V/5200mAh
Model:18650C
Charging limited:4.2V
Date: 2022L1
M
DeniseCabral - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 28
Últimos 30 dias: 160
Ao todo: 8,025
