Ir para o conteúdo principal
JVC Adixxion GC-XA1BU Lens (External) Replacement
O que você precisa
  1. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery: passo 1, imagem 1 %32
    • Find the side of the camera that looks like this.
  2. JVC Adixxion GC-XA1BU Lens (External) Replacement: passo 2, imagem 1 %32
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Lens (External) Replacement: passo 3, imagem 1 %32
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. JVC Adixxion GC-XA1BU Lens (External) Replacement: passo 4, imagem 1 %32 JVC Adixxion GC-XA1BU Lens (External) Replacement: passo 4, imagem 2 %32
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Lens (External) Replacement: passo 5, imagem 1 %32
    • You can now take the battery out of the camera.
  6. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery Cover: passo 6, imagem 1 %32
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
  7. JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): passo 7, imagem 1 %32 JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): passo 7, imagem 2 %32
    • Using a 1x1xH1.5 torx screwdriver, remove the eight screws (5mm headsize / 4mm length) from the corners of both sides of the camera (4 screws on each side).
  8. JVC Adixxion GC-XA1BU Lens (External) Replacement: passo 8, imagem 1 %32 JVC Adixxion GC-XA1BU Lens (External) Replacement: passo 8, imagem 2 %32
    • Twist the metal ring on the lens to the right and then pull it off.
  9. JVC Adixxion GC-XA1BU Lens (External) Replacement: passo 9, imagem 1 %32 JVC Adixxion GC-XA1BU Lens (External) Replacement: passo 9, imagem 2 %32
    • Use the plastic opening tool to gently pry the lens off of the camera.
Conclusão
Equipe
USF Tampa, Team 1-2, Tanski Winter 2015 Membro de USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
Membros da 4
Autoria de 8 guias
Um comentário
Where can the lens be purchased at?
Isaac Aguilar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 621
