Ir para o conteúdo principal
JVC Adixxion GC-XA1BU Battery Cover Replacement
O que você precisa
  1. JVC Adixxion GC-XA1BU Battery Cover Replacement, Battery: passo 1, imagem 1 %32
    • Find the side of the camera that looks like this.
  2. JVC Adixxion GC-XA1BU Battery Cover Replacement: passo 2, imagem 1 %32
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Battery Cover Replacement: passo 3, imagem 1 %32
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. JVC Adixxion GC-XA1BU Battery Cover Replacement: passo 4, imagem 1 %32 JVC Adixxion GC-XA1BU Battery Cover Replacement: passo 4, imagem 2 %32
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Battery Cover Replacement: passo 5, imagem 1 %32
    • You can now take the battery out of the camera.
  6. JVC Adixxion GC-XA1BU Battery Cover Replacement, Battery Cover: passo 6, imagem 1 %32
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 1-2, Tanski Winter 2015 Membro de USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 1,286
