Introdução
This guide will provide instructions on how to remove the back case and replace the battery.
O que você precisa
Turn the phone off by holding down the power button located on the top of the phone.
Find the small indentation at the bottom right of the phone and pry open the back case of the phone using your fingernail or small plastic opening tool.
Gently remove the back case completely from the phone.
Insert a fingernail or the small plastic opening tool into the recess in the bottom center of the battery and lift upward.
Remove the battery from the phone.
Uma outra pessoa concluiu este guia.
